Lines and Arrows
Lines and Arrows
Latest version.
Just wanting to make sure I understand things.
If I draw a line in the Input and Preview mode, and click OK, the line shows in the result.
However, if I just opt for the Display Input mode, and draw a line, the Input image shows the "set up" lines etc. but when I click OK, the resulting image does not show the line.
If I initially show the Input image only and set up the line, then change to the side by side mode and click OK, the line is present in the final image.
Is it supposed to work this way?
Re: Lines and Arrows
No, it's not. Fixed for next release.
Also, it appears, in Display Input mode only, Ctrl+Click does not remove a point(s) unless a third point is added (anywhere on the image). Once the third point is added, all/any points can be deleted. Exists for both Straight and Curved lines.
In Side by Side mode, Ctrl+Click works as expected.
