Update Available - Version 8.0.82
An update is available to Version 8.0.82 (9-Apr-2020)
Fixed problem causing image display not to be color managed when show highlight or shadow clipping was enabled.
File Preferences: removed second clipping color. Added a new tool bar on the main menu to select which color space is used to detect highlight clipping: HSV value or HSL lightness. In HSV, it indicates if any highlight channel is clipped (fully saturated color). In HSL, it indicates if all channels are clipped (white). For either HSV or HSL, shadow clipping indicates black. The new tool bar is only displayed if the highlight clipping button is depressed. You will need to do a full install to get two new bitmaps.
