Update Available - Version 8.0.66
An update is available to Version 8.0.66 (19-Mar-2020)
Line and Arrow tool: renamed to Lines, Arrows, Text. Added Text button which pops up a dialog box to let you enter text to be placed at the starting point of the current line. See the updated help file or Transformations.pdf for details.
Create Profile: fixed problems with running the transformations in locales which use commas instead of periods as decimal points.
Color Picker: Ctrl-click and Ctrl-Shift-click now bump brightness slider as for other sliders.
ExifTool: updated to version 11.91
Added an autosave workspace after a successful File Open of an image file.
Mask: disabled loading of default settings file which was not working properly -- will provide a more permanent fix later.
Re: Update Available - Version 8.0.66
Lots of cool new bits to absorb... but when I first tried "Lines, Arrrows, Text" I get an error msg saying ...Text.bmp was missing. The transformation opens, can open and enter text in the text control window just fine. Did manage to silently crash PWP, when Crtl-clicking to remove a line, but haven't been able to reproduce it, yet.
I am re-posting as 8.0.67 shortly with the missing file included.
