Update Available - Version 8.0.63
An update is available to Version 8.0.63 (9-Mar-2020)
Print: fixed problem with not recognizing printer curves with the extension “.cc”.
Added Edit/Clone Branch command (also added to right-click on thumbnail menu). This inserts a splitter above the current image, unless there already is one, and then copies the current image and all the ones below it in the image tree to the new branch.
Re: Update Available - Version 8.0.63
Jonathan, it is very kind of you to restore this command.
Thanks.
