Update Available - Version 8.0.60
An update is available to Version 8.0.60 (5-Mar-2020)
Fixed problem with Replace Channel transformation if Channel Image was set to a Bypass transformation.
Distort Transformation: added a new method: Inverse Multiquadratic.
File New: added a Reference Image control. If an image is selected, its type, width, height and dpi are copied to the other controls. You can still change one or more of the settings manually after selecting the reference image.
Re: Update Available - Version 8.0.60
Just downloaded latest version, and tried "File New".
Had a single image open (48 bit color), and wanted a matching new image. However, the only two options I was able to get was "No Image" and "Load". Load took me to a folder. The image I had open did not show in the list.
Fixed for next release -- it was not recognizing 16-bit B&W or 48-bit Color images.
