Line and Arrow, Paint
2 questions/issues:
I used the Line and Arrow tool, in hopes of drawing multiple perfectly horizontal and vertical lines, but it appears (at least that I can find) the tool does not have that capability, without some fiddling. I tried first setting a grid on the page then using the grid lines as guides, then redoing the line on a blank page using Reload last settings, but that becomes quite cumbersome for multiple lines. Is there an easy method to achieve this?
And, I also used the Paint tool, with a specific line width to draft multiple lines across the page from edge to edge, where they were not perfectly horizontal and criss-crossed each other. In an attempt to do this easier and in a more fluid manner, I reduced the size of the page by zooming out, then criss-crossing the page in multiple lines (where I started and ended off the page).
However, the program introduced "+" marks (temporary) along the pen path but often only drew the line to the last "+" mark, rather than taking the line right to the edge (even though I could actually see the line following the pen to the edge). This was hit and miss as to whether the line was drawn to where the last "+" had been set or to the edge. I thought the speed at which I was swiping the pen across the page may be contributing to this, so I slowed that action but the problem persisted.
Second issue, if I clicked OK and closed the tool, then re-opened it to draw more lines of the same width/color, when I tried Reload last settings, a warning "Paint input does not match original image dimensions. Clear all painting?" appeared. Not knowing what this meant, I clicked OK, which caused PWP to crash.
Re: Line and Arrow, Paint
That may not solve the issue, but there is a Grid transformation in the Special Effects. Multiple application of that using different settings may get you the arrangement of the horizontal/vertical lines that you want.
For the next release I added a button that lets you constrain the slope angle to increments of 45 degrees, making it easy to create horizontal, vertical, or 45 degree lines and arrows.
I have not been able to reproduce the issue with Paint crashing after Reload Last Settings. From the message you got it looks like you tried to apply paint settings from one image to a different image that was a different size, and hence the warning. In any case it should not have crashed -- instead it should have opened the paint tool without repainting the strokes from the last time you used it.
