Update Available - Version 8.0.47
An update is available to Version 8.0.47 (15-Feb-2020)
Modified Change Name dialog box (used to change the caption of a thumbnail) to have an OK and Cancel button, with OK the default pushbutton so it is selected on Enter.
Image Browser: removed Select None button from Select tool bar. If no images are selected, Select All selects everything – otherwise it deselects everything. Select all downstream or upstream images now deselects if the current image is already selected.
Fixed some problems with running scripts produced by older versions of PWP.
Mask Paint Tool: Accumulate and Don’t Accumulate buttons were reversed.
