Update Available - Version 8.0.44
An update is available to Version 8.0.44 (9-Feb-2020)
Fixed problem with incorrect cursor sometimes being displayed when moving the cursor over the main image area for certain transformations.
Fixed problems with Esc and Return emulating Cancel and OK in transformation dialog boxes. There is still a problem with transformations (Text and, in some cases, Layout) when a multi-line edit control has the focus. You can still use Esc and Enter in these cases as long as you click on the main image area first.
Precise Gaussian Blur: fixed problems, especially with radius > 32.
Workspace Scripts: saving Autosave and Previous workspace scripts no longer records them as the last workspace script saved.
Editing a transformation and clicking OK or Apply now changes the S to an M in the image browser, indicating the image is potentially changed since the last time it was saved.
Re: Update Available - Version 8.0.44
I'm not sure if I understand this change.
When you go to save or load a workspace script, Autosave is no longer listed as the last workspace script used.
Previously, when you autosaved a workspace, it was marked as the last saved and its name replaced any name you manually saved under. This has no real value as the autosaved workspace always has the same name so it is not hard to remember.
