Update Available - Version 8.0.25
An update is available to Version 8.0.25 (29-Dec-2019)
Export: added the option to save the exported file to the original folder or to a custom folder. Be careful with this option as it is possible to overwrite your original files by accident.
Autorange: changes in the dynamic range slider are now reflected in the curve. Fixed problem causing crash when recalculating Autorange transformation in some cases.
Brightness Curve: added Reset Advanced Mode Settings to Settings menu. Fixed some problems with restoring the Antialias setting from the command line.
Fixed problem with extracting certain Unicode profile names from v4 ICC profiles.
Color Balance: fixed problem with auto settings not being applied correctly when the transformation was executed.
