Transformation Brightness Curve
bulrichl
Post by bulrichl »
Hello,
I posted this a while ago but did not get a respond from the developers, therefore again:
I encountered a problem with the transformation Gray/Brightness Curve... (PWPro 5.0.1.2, Windows XP Home, Service Pack 3):
1) Open a 48-bit color TIF picture,
2) call the transformation Gray/Brightness Curve,
3) choose Color Space: RGB,
4) close the transformation,
5) call the transformation Color/Extract Channel,
6) choose Channel: Red and click on OK,
7) call the transformation Gray/Brightness Curve.
The histogram of the monochrome picture (the red channel) is obviously incorrect. This bug has been in previous versions of PWPro (4.0 and if I remember correctly, 3.5 likewise).
Kiril, Jonathan: could you have a look at it?
Bernd
Bob Walker
Re: Transformation Brightness Curve
Post by Bob Walker »
Bernd,
I can confirm what you see.
Some other observations:
(1) 48-bit TIF not required -- 24bit Jpeg shows same issue.
(6) Red channel not required, histogram shown is also wrong for extracted green channel (and probably blue channel).
The wrong histograms just show a spike or two at the 50% brightness level.
The new histogram tool for the grayscale color channel is OK.
BobW
Thanks, I have fixed this for the next maintenance release.
bulrichl
Post by bulrichl »
Jonathan,
oh, I am the one to thank you! As I often work with color pictures and monochrome channels simultaneously, this strange behaviour happened frequently. So I will be very happy when it has been fixed.
Bernd
