Update Available - Version 8.0.22
An update is available to Version 8.0.22 (24-Dec-2019)
Fixed problems with false warnings about image size change and problems with canceling from a size change warning in some cases not cleaning up the image tree correctly.
Fixed problem with the current grid setting not being checked in some cases in the drop down grid menu from the main tool bar.
Fixed problem with tool tips getting cut off at the bottom of their parent window.
Added new Fill transformation (under Transformation/Tools). This tool lets you set one or more fill points and it then does a flood fill around each point to determine a fill region. The fill region is then filled with a selectable solid color. Each fill point can have its own fill threshold and fill color. See the help file or Transformations.pdf for more details.
Re: Update Available - Version 8.0.22
Fill Transformation looks interesting. But if I Shift-Click outside of the image PWP silently closes. However I can drag an existing point outside of the image without causing any problems.
