Update Available - Version 8.0.19
An update is available to Version 8.0.19 (14-Dec-2019)
Hotspot: now lets you drag the center of the hot spot to any desired location in the input image.
Added new Geometry/Size to Fit transformation. It resizes a cropped area of its input image to the same dimensions as its output image using one of four different methods. See the updated help file or Transformations.pdf for details.
Script files are no longer stored by default in the Scripts folder. The default location is now the last folder to which any image or script file was saved. When opening or saving scripts from the main menu, their names are now added to the recently used file list at the bottom of the File menu. Workspace scripts are not affected by this change.
Updated to ExifTool 11.79.
Re: Update Available - Version 8.0.19
"Hotspot: now lets you drag the center of the hot spot to any desired location "... Cool. Is it possible to add this functionality to other transformations, especially Blur: Zoom Blur?
Added the feature to Zoom Blur for next release.
You, sir, are the best. Thank you.
