Selective Color Correction Dialog Height
Ref: PWP 8.0 v8.0.13
For my Laptop display [1366x768 pixels] the Brightness slider for a 'active' Control Point is out of frame even with the bottom Task Bar hidden and the Program Window is Full Frame...
Screenshot (1).jpg (62.71 KiB) Viewed 1702 times
Access to the slider is barely possible by a left-click drag upward of the transform title bar... ...could perhaps the spacing between transform dialog elements be decreased?
Thanks... ...den...
Re: Selective Color Correction Dialog Height
I can try to compress the dialog box a little -- in the meantime, if you decrease the font size (File/Font Size...) a little it will make everything smaller.
