Quick Pick suggestion
I just discovered Quick Pick - super convenient! If I press the letter, the selection of transformations is small and easy to choose from. But if spacebar is pressed, the table is centered on the screen with the leftmost column containing the latest numbered transformations hidden, unless I move the table to the right.
I'm not sure what's feasible, but I would find it faster if all the most-used transformations, starting from any letter were immediately visible upon pressing the spacebar. Maybe the table could start from the left edge of the screen rather than centering itself for example? Or maybe allowing more rows?
Annotation 2019-11-22 023650.png (59.08 KiB) Viewed 1374 times
Re: Quick Pick suggestion
I guess you can tell I test on larger monitors. I'll see what I can do to make it fit on smaller ones.
Works perfectly now. Cheers!
