Confused on blending modes...
priort
Post by priort »
I was trying to determine how to do an "overlay" blend mode and perhaps multiply...Terminology in Picture Window is a bit different...reading the documentation it sound like the filter transform is like multiply but I was not able to sort out a way to do an overlay ie dark darker light lighter and middle gray no change....just wondering...likely I am just missing something in trying to distinguish between the blend, filter and compose transforms...
Re: Confused on blending modes...
The Photoshop Overlay blend mode is called Reverse Hard Light in PWP's Blend transformation since it is the same thing as Hard Light with the images switched.
Multiply is called Filter
Screen is called Subtractive Filter
The Filter transformation is pretty much subsumed within Blend.
Composite is for when you need to scale or reposition an overlay image on a base image.
Isn't "dark darker, light lighter, mid no change" similar to Soft Light. Although Soft Light punches up the saturation a bit.
priort
Post by priort »
Jonathan thanks for the clarification....one reason why I was asking is I was trying to perform the equivalent operation to obtaining the average colour of the entire image and then using the inverse colour applied with either overlay or softlight to see how that compared with a few methods that you have built in for color casts....this is what I was trying to replicate or something like it...https://www.youtube.com/watch?v=1ZIGDx4Bg-k
