1. create a new layout (my is default portrait oriented)
2. load a landscape oriented image -> you get the message about the exceeding the output size -> click OK
3. go to settings - Load Settings - load a predefined landscape oriented layout -> the panel rectangle disappears from the page leaving a small hair cross in the page, but the image stays loaded - see the attachment
4. click on the cross -> it disappears toghether with the loaded image
5. add a new panel using the "plus" button and reload the image (is is still highlighted in the image list even though it is not reloaded yet) -> from this moment you have two halfsized thumbnails next to the Layout thumbnail (the image on the right of the attachment)
6. remove the current panel using the "minus" button -> the panel disappears from the page, the small hair cross is back and the image stays loaded,
etc.
Now, if you at the step 4. instead of clicking on hair cross just reload the loaded image, the panel with the image get back.
Layout with one image but two halfsized thumbnails
- Layout with one image and two thumbnails.png (9.72 KiB) Viewed 1240 times
Re: Layout with one image but two halfsized thumbnails
