Bug fix release 21-Aug-2019
I have posted a new release (21-Aug-2019).
Fixed problem with the view mode that displays only the image browser.
File Save: fixed auto-incrementing version numbers.
Fixed problems with loading saved float curve files.
Add Texture: added new features to provide different methods for applying texture (see help file or Transformations.pdf for details)
Crop and Tile: fixed problems when input image size changes while dialog box is still open.
Modified code to select pathnames for opening or saving to stop using obsolete methods.
Grid transformation: increased limits on number of grid divisions to 9999 and line widths to 100.
Amount masks: fixed problem causing potential mask images to not show up on the mask menu in some cases.
Mask: fixed problem with overlay not being erased after Apply for various mask tools and problem with not being able to drag right and bottom sides of the bounding box for the Polygon and Spline tools.
Image Info: fixed problem causing incorrect placement of some controls.
rfuerman
Re: Bug fix release 21-Aug-2019
Post by rfuerman »
File | Open Multiple . . Open image File dialog & select two images =
click [OK] returns user to open image file dialog.
Same result with png images. Worked OK with July beta version.
Thank you! Bob
I found another, more serious problem with this release and will re-issue it shortly. Please wait until 21.5-Aug-2019 version before downloading.
