Open a file image can cause a crash
1. open a file image
2. optionally add some transformations
3. close PWP, when asked, save it or not to a script
4. restart PWP and load previous session workspace or the last saved workspace depending on the previous step
5. when the workspace is loaded click File Save As or use the Menu command Save As... -> PWP crashes
It happens also when a branch box, not an image, is active.
It happens only after PWP is restarted and a script is loaded, not in a new or cleared workspace:
If you instead of step 5 clear the browser of all images, repeat the steps 1 and 2, then you can save any image without the crash.
Re: Open a file image can cause a crash
Fixed for next release
