Bug fix release 8-Jul-2019
I have posted a new release (8-Jul-2019).
Fixed problem with Edge transformation for 24- or 48-bit color input images, operation = Compute, Color Space = HSV or HSL, and Amount < 100%.
Updated the description of cloning from one image to another in the help file.
Clone: fixed problem causing no image to be selected after an immediate Cancel.
Clone: fixed problem causing remnants of the overlay circle to be left behind while cloning.
Clone: fixed problem causing uncontrolled results when doing too rapid a series of strokes in some cases. Now, strokes initiated before the last stroke is finished processing are ignored.
Print: fixed problems with cropping overlay in input image.
Clone, Paint, Smudge: added commands to Settings menu to Save as Default Brush and Clear Default Brush. The default brush file is loaded on startup if present, providing a way to initialize the brush settings for these transformations. Also, settings files for these transformations now save and restore the current brush settings. Now when the transformation are editing, their brush settings are restored.
Fixed some problems in loading saved brush files.
The “S” icon in the image browser that indicates an image has been saved now changes to an “M” if the image has been recalculated (and thus potentially modified) since it was last saved.
Hotspot: changed the way the transformation darkens images from multiplicative to subtractive.
