Bug fix release 4-Jul-2019
I have posted a new release (4-Jul-2019).
Added new transformation called Gray/Hotspot for darkening the central hot spot you often get when taking IR (infrared) photographs.
Clone: changed default Overlap setting to Yes to correspond to the way PWP 7 works.
Clone: fixed problem causing crash when specifying an input image but not creating any strokes and then clicking OK.
Clone: fixed various problems with switching between cloning from one image to another followed by cloning within the output image and then clicking Undo.
Fixed problem with dependency logic that was failing to identify some downstream dependencies.
For transformations that take auxiliary inputs (e.g. Clone, Composite, Filter, etc.), the display buttons at the top of the transformation dialog box now display the following two images, depending on the button pressed:
  • Input Only Button: displays the input image, if any, if the transformation image is selected in the image browser – displays the auxiliary input image if an input thumbnail next to the transformation image is selected.
  • Output Only Button: displays the output image.
  • Both Button: displays the input (as defined above) and output side by side.
Mask: fixed problems with mask speck removal tool.
When canceling a transformation, the partially computed output image is now set to all black.
Gaussian Blur: modified Orton Effect settings file.
