Bug fix release 28-May-2019
I have posted a new release (28-May-2019).
Fixed problem with size of curve control in Oval and Sweep Gradient transformations when Curve is selected instead of Color Line in the Settings menu. Fixed problem with width of Scale slider in Multipoint Gradient transformation.
Added support for reading a TIFF variant used by ON1 with a pre-multiplied alpha channel.
Added support for Topaz DeNoise AI under File/Plug-Ins. While quite slow, DeNoise AI provides very good noise reduction, at least for some images. If you own the previous Denoise plug-in, the upgrade is free. Make sure you get the latest version as they just fixed a bug that made it not work with Picture Window.
