Bug fix release 12-Apr-2019
I have posted a new release (12-Apr-2019).
When saving scripts at the same time as saving image files, the script name now includes both the image file extension and the “.script” extension. This prevents overwriting script files if an image is saved in the same folder as two different types. For example, saving an image as xxx.tif saves its script as xxx.tif.script.
Levels and Color: fixed problem of Reset not recomputing black and white points correctly if color space was set to HSL at the time of the Reset.
Print command: clicking on another image in the image browser no longer leaves a print command thumbnail behind – the print dialog is closed and the thumbnail removed.
