Cloned bypassed transformations do not refresh previews
1. open an image
2. run it through a transformation
3. turn the Bypass button on
4. use Clone Side Branch to clone the bypassed image
5. reopen the cloned bypassed transformation -> the Bypass button gets turned off
6. toggle between Display Input and Preview buttons -> all previews will show only the image before applying the transformation
7. click Brightenss Apply or OK button -> the previews do not get refreshed
8. click OK button, reopen the transformation and toggle the preview buttons -> still no change in previews
9. make some change in settings, e.g. in Amount -> the previews get refreshed
This seems to happen with the transformations (I did not try all) without their own preview.
With the Brightness transformation (and perhaps some more) it is different: when you click Apply button in the step 7, the previews get refreshed.
Original (not cloned) bypassed transformations normally show the transformation effect when the preview buttons are toggled (step 6).
