Bug fix release 19-Mar-2019
I have posted a new release (19-Mar-2019) in full installer and executable-only versions. Minor changes to help file.
Texture transformation: now generates the same set of random patterns each time and does not advance to a new set until you click the randomize button. This lets you adjust the other settings without re-randomizing the pattern each time. Also, each time you run the transformation it will regenerate the same texture as the last time.
