Bug fix release 8-Feb-20198
I have posted a new release (8-Feb-2019) in full installer and executable-only versions. Minor changes to help file.
Calendar: fixed problems with settings not being restored correctly on double-click or loading saved settings file.
Color Remap: fixed problem with dialog box being displayed the wrong height in some cases and problem causing dialog box not to go away with switching to another image.
Emboss: changed the initial default angle setting so light appears to come from the upper left
Levels and Color: fixed problem with dynamic range readout not being updated on Reset.
Red Eye Removal: fixed problem with output image not being restored correctly when the transformation was edited.
Paint: fixed problems with brush overlay displaying on input image instead of output image. Like Clone, Paint is applied directly to the output image.
Tile: fixed problem causing a crash if the input image size was reduced by a preceding transformation. This may have affected other transformations as well. It is possible this bug fix will cause other problems.
Transformations and Controls documents are now complete although they could use some polishing.
