Bug fix release 30-Jan-2019
I have posted a new release (30-Jan-2019) in full installer and executable-only versions. Minor changes to help file.
Added a Maximize Box to Image Browser when it is displayed in a separate window.
Added a command with keyboard shortcut Num – to close the current image, if any. You can now use the tab key to move between the buttons in the confirmation dialog box.
Combine Channels: fixed problems with no images selected and color space set to HSV or HSL. Also, its menu item is now always enabled since it does not need an input image to run.
Mask: fixed problem with Paint tool not applying mask mode changes correctly.
Added more documents to downloads page.
