Two things about printing
A.
1. click the Printer icon on the menu bar or select the Print... command from the File menu -> this will add an empty Print thumbnail
2. close (x) or Cancel the Print dialog without doing anything -> the empty Print thumbnail is not automatically closed and clicking it does not recall the dialog
3. you have to close the Print thumbnail manually
B.
1. the same as at A
2. click Print button -> you got a message Settings file C:\users\"username"\Documents\Picture Window Pro\Print\Default.print command line starts with wrong command:0
3. close (x) or confirm (OK) the message -> the PWP Print dialog opens and the empty Print thumbnail gets completed - filled with the image miniature, OK
4. Cancel or close (x) the PWP Print dialog -> the Print thumbnail is closed, OK
