menus
rfuerman
menus
Post by rfuerman »
Hello. PSP 1/11. Some UI menu suggestions for you:
reference: https://docs.microsoft.com/en-us/window ... /cmd-menus
1) new View Menu : Consider adding a 'View' menu item. This would include: from toolbar: four 'Show image browser & image' variations, readout, histogram, and palette, clipping, and grid; zoom in or out commands for image window. From help menu: 'Display image tree.' If multiple images are open, include an image selection sub menu = 'switch window'. From File menu: 'White screen.' From Edit menu: 'Full Screen', 'image info', 'Select' and 'Move' items (none of these are really edit items). New 'Show toolbar' option. If toolbar can be hidden, then all toolbar commands should also be available on menu.
2) new Edit | 'settings' sub-menu. Little used option items such as File | Preferences, Color management, Monitor/printer curves, and Gray calibration; Plug in setup, Default folder (?? maybe?), can be put here.
3) menu | transform | geometry | crop. Please add 'Original ratio' i.e. preserve image proportions, to the Proportions list. Perhaps move the [ ] Resize options up to under the Proportions selections?
And thanks for fixing the File | open routine when multiple files selected. Working fine, today! Bob
Re: menus
Thanks for the menu suggestions, but at this point I am disinclined to shuffle the menus. Microsoft is famous for defining standards and then ignoring them and then revoking them and defining new standards.
The extra option in Crop is a good idea.
