Bug fix release 4-Jan-2019
I have posted a new release (4-Jan-2019) in full installer and executable-only versions. Minor changes to help file.
Zero-centered amount controls (e.g. Brightness or Displace transformations) now initialize new masks to gray instead of black.
Removed Print Setup button from Print dialog box – it turns out Windows does not allow a Windows Print Setup without also running the Windows Print dialog box afterwards.
File Open: if multiple files selected, they are each opened in their own top-level image. To open multiple files in a single top-level image as a file list, first open one of the files and then add the others to the list using the File Open tool bar.
Swap Channels: fixed problems restoring transformation when editing by double click on thumbnail.
Continuing work on Tutorial.
