Text size
Text size
Hello
I've created Text in PWP with a font size of 110 pixels, font is Arial.
I now try to determine the text size in points to create matching text with a other program.
The i measured (with the arrow tool) the hight of numbers created with above setting and found out 70 pixel.
Then i measured "dg" , to measure the underline too, to abt 90 pixel.
How does the font size comapre to the measured hights ?
And is maybe a simple factor to calculate the points from the font size in pixels ?
Thanks
Re: Text size
This calculation is internal to Windows -- I suspect it is based on the nomial dpi of the display. Actual character heights vary from font to font as well.
Re: Text size
Thanks, Jonathan
I have done it with try and error to find the right font size in points.
Font is Arial and for a pixel size in PWP of 110 i found a size of 73 points.
