Open Script: "Warning File does not exist: Use a replacement file?"
Ref: PWP 8.0.exe (Dec 11, 2018) with msi (Nov 30, 2018)
1) open an image (48 bit tiff, 4000x3000 pixels), create a script and save script without image names.
181211 TESchmitz Glow Effect 1 ori.script
script 1.0
color_management enabled 1 on_mismatch 0 acs_profile ″sRGB Color Space Profile.icm″ gray_acs_profile ″Gamma 2.2.icm″ wcs_profile ″sRGB Color Space Profile.icm″ gray_wcs_profile ″Gamma 2.2.icm″ monitor_curves_file ″″ monitor_curves_enabled 0
image index 1 caption ″File Open″ saved_as ″″ saved_on ″″ parent -1 bypass -1 same_size 0 size_specific 0 breakpoint 0 n_inputs 0 n_masks 0 command ‴file_open 0 n_files 1 current 0 show_progress 1 from_default 0 file1 ″″ time1 ″″‴
end_image
image index 2 caption ″Brightness Curve″ saved_as ″″ saved_on ″″ parent 1 bypass 0 same_size 1 size_specific 0 breakpoint 0 n_inputs 0 n_masks 1 command ‴brightness_curve 0 curve 3 3 0 0 128 166 255 255 colorspace 2 advanced 1 radius 10 threshold 100 detail 1.199 antialias 0 mask_histogram 0 display 2 sync_scroll 1 auto_preview 1 amount 1 -1 0 0 ″Amount: ″ ″Mask″‴
end_image
image index 3 caption ″Brightness Curve″ saved_as ″″ saved_on ″″ parent 2 bypass 0 same_size 1 size_specific 0 breakpoint 0 n_inputs 0 n_masks 1 command ‴brightness_curve 0 curve 3 3 0 0 128 166 255 255 colorspace 2 advanced 1 radius 10 threshold 100 detail 1.199 antialias 0 mask_histogram 0 display 2 sync_scroll 1 auto_preview 1 amount 1 -1 0 0 ″Amount: ″ ″Mask″‴
end_image
image index 4 caption ″Gaussian Blur″ saved_as ″″ saved_on ″″ parent 3 bypass 0 same_size 1 size_specific 0 breakpoint 0 n_inputs 0 n_masks 1 command ‴gaussian_blur 0 radius 20 threshold 255 what 0 amount 1 -1 0 0 ″Amount: ″ ″Mask″ display 1 sync_scroll 1‴
end_image
image index 5 caption ″Composite″ saved_as ″″ saved_on ″″ parent 4 bypass 0 same_size 1 size_specific 0 breakpoint 0 n_inputs 1 n_masks 2 command ‴composite 0 operation 3 alignment 0 nalign 0 label 1 overlay_color ffffff overlay_amount 1 -1 0 0 ″Overlay Amount:″ ″Overlay Mask″ amount 1 -1 0 0 ″Amount:″ ″Base Mask″ display 2 sync_scroll 1 auto_preview 1 ‴
input base_image 5 input_number 0 index 1 caption ″Overlay″
end_image
end
2) close PWP8, do not save workspace script.
3) open PWP8
4) select Open Script... and double click the previously saved 1) script.
5) "Warning File does not exist: Use a replacement file?" appears... ...select OK. Open Image File dialog appears.
6) select an image (perhaps the same one upon which the script was based)... ...PWP hesitates for a second, then disappears from the desktop with no warnings or errors.
Selecting a different smaller (pixel dimensions and/or file size) jpeg image version will also result with PWP8 disappearing from the desktop, no warnings or errors.
On one of ten tries, I got this:
Screenshot (1).jpg (23.55 KiB) Viewed 1565 times
This will consistently happen even with lowered OS performance settings using my laptop described as:
Operating System
Windows 10 Home 64-bit
CPU
AMD A10-8700P 41 °C
Carrizo 28nm Technology
RAM
8.00GB Single-Channel DDR3 @ 798MHz (11-11-11-28); Threads 4; CUDA not availabe
Motherboard
HP 80AF (P0)
Graphics
Generic PnP Monitor (1366x768@60Hz)
512MB ATI AMD Radeon R6 Graphics (HP) 40 °C
Storage
931GB Hitachi HGST HTS541010A9E680 (SATA) 28 °C
Optical Drives
hp DVDRW DU8A6SH
PWP 8.0.exe version 181207 behaved similarly.
Re: Open Script: "Warning File does not exist: Use a replacement file?"
Fixed for next release
