Bug fix release 30-Nov-2018
I have posted a new release (30-Nov-2018) in full installer and executable-only versions. Some changes to help file.
Added a new group of transformations under the Transformation/File submenu. Taken together, these transformations provide a batch processing facility. The Batch transformation provides a list of files to operate on and manages their sequential loading and recalculation. The Export transformation exports its input image when running in batch mode. Similarly, for the Print and Display transformations (Print is not yet implemented). You will need to download the full installer to get new bitmaps. The updated help file describes the new transformations.
Added new Edit commands for full screen display (Ctrl-F shortcut) and setting and clearing batch breakpoints (breakpoints are not implemented yet).
File Export: fixed problems with JPEG Quality slider not being updated in some cases and several other problems with saved settings. Added some new export options as well in preparation for batch operations (see above).
Linear Blur: fixed problem with blur at angles other than multiples of 90 degrees had a dark border.
Image menus now close automatically if there is no mouse activity in the menu for 4 seconds or if you press the Esc key.
Drop Shadow transformation: fixed problem causing transformation to think there was an error when everything was OK in some cases.
