Monitor curve missing on start
If you load a Monitor curve while you work and at the end of the session confirm Save workspace for later, next time you restart PWP you get warning messages about changed script and missing files.
Even when you reset the loaded monitor curve before you end the session (and save workspace for later) you get warning messages.
To prevent this you need to:
- confirm the messages on PWP start (this removes any record of the curve)
- overwrite the workspace by resaving it either from the menu Script or by using Save workspace for later at the end of the session
It looks as if the script knows about the loaded curve but is unable to find its location.
Also, it seems that loading a curve is recorded but resetting the curve is not.
Re: Monitor curve missing on start
Fixed for next release
