Bug fix release 2-Sep-2018
I have posted a new release (2-Sep-2018) in full installer and executable-only versions. Minor changes to help file.
Selective Color Correction: fixed problem with output not being updated after loading a settings file.
Layout: fixed problem of background image not being cleared on Reset. Reduced flashing, in part by not automatically making the image associated with the current panel be selected as the current input which caused the main image area to be refreshed with a view of that input image. To edit the cropping for an input image, you must now select it manually by clicking on its half-size thumbnail in the image browser. If there is no default settings file, layout units are set to match the default units from File/Preferences and snap grid and display grid are set to round numbers in those units (for cm or mm, 0.5 cm and 2.0 cm – for pixels or inches, 0.25 in and 1.0 in).
