Bug fix release 31-Aug-2018
I have posted a new release (31-Aug-2018) in full installer and executable-only versions. Minor changes to help file.
Median Blur: added Variable method with slider to adjust median radius. Variable median is a fast, close approximation to the precise median.
Adjust: in the Curve tab with Color Space set to RGB, added an All channel option in addition to R, G, B. This displays a combined RGB histogram and applies the same curve to all three channels, same as Brightness Curve does in RGB mode.
Color Curves: same as above, added new All option to RGB color space.
