For consideration... ...Add a Luminance curve to Adjust RGB Curves Tab
Ref: PWP 8.0.exe 180828
From Update log 180828:
Adjust: Added RGB as a color space option for the Curves tab.
Please consider adding a 4th channel curve choice [perhaps 'RGB' or 'Lum'] in addition to the R,G, and B channels of the Adjust - Curve tab when the RGB color space is selected... ...ie., same as a Brightness Curve in the RGB color space.
This would be in keeping with the Adjust transform falling under the Gray menu drop downs...
