Bug fix release 18-Aug-2018
I have posted a new release (18-Aug-2018) in full installer and executable-only versions. Minor changes to help file.
Masks that are reset are no longer included in script files.
Fixed bugs in Copy & Move causing incorrect recalc after operation.
Posterize – color pickers are now closed after a reset or when loading settings.
Added new Bypass transformation that simply passes its input through to its output. See the updated help file for an example of when it can be useful.
When saving JPEG or TIFF files, options are grayed out if they have no effect. For example, if there is no GPS data, the GPS option is grayed out.
Re: Bug fix release 18-Aug-2018
Many thanks for the implementation of my enhancement request.
The Bypass Transformation does the trick.
