Bug fix release 17-Aug-2018
I have posted a new release (17-Aug-2018) in full installer and executable-only versions. Minor changes to help file.
Watercolor: Fixed display mode problems.
Autorange: Fixed several problems with color space setting.
Image Info: If an image has been saved since it was opened, the filename and folder it was saved in is now displayed in addition to the filename and folder of the file from which it was derived.
Fixed bugs related to saving or restoring file information from a File Open when loading and saving scripts.
Fixed problem allowing two Image Info dialog boxes to be open at the same time if the image browser is in a separate window.
Fixed problems with determining downstream dependencies of side branches. Closing a side branch now closes all dependent images, including those that reference images in the side branch as auxiliary inputs.
Re: Bug fix release 17-Aug-2018
Thanks for the Image Info addendum.
