Auto Range [Autorange] does not remember HSL Color Space setting
Ref: PWP 8.0.exe 180816
1) Open a known "less than full range" color image in the Browser.
2) Open the Autorange transform... ...transform opens in the HSV color space with curve and histogram and calculates an updated Output.
3) Switch to the HSL color space... ...transform re-calculates and Output updates with no change to curve or histogram display.
4) Select Settings-Reset... ...transform re-calculates and curve updates with no change to the Output or histogram... ...believe the histogram remains HSV-V rather than HSL-L of the Input image and the Output image is the same as 3).
5) Select OK to close the transform.
6) Select Edit Transform... ...transform dialog shows HSV as color space with its associated curve/histogram rather than the step 3) - 4) HSL setting.
Also... ...when saving an OK-ed transform with HSL settings as a *.script, the resulting Open *.script file will open with HSV color space, curve and histogram settings.
Re: Auto Range [Autorange] does not remember HSL Color Space setting
