Bug fix release 13-Aug-2018
I have posted a new release (13-Aug-2018) in full installer and executable-only versions. Full install required to get the new bitmap for the Median Mask tool and the updated help file.
Fixed bug causing crash in Quick Pick.
Added two new Mask tools: Remove Pinholes and Median Filter – see updated help file for details. Remove Pinholes is similar to the Speck Removal phase of Advanced Sharpen – it fills in small white and/or black specks in the current mask. This helps automate cleaning up holes in masks left behind by other tools such as Range or Flood Fill. Median Filter does what the name implies – while it also removes small specks, it also rounds off pointed corners, making the boundaries between black and white smooth curves. This can be a useful precursor to the Blur tool for creating dodge and burn masks.
