Bug fix release 10-Aug-2018
I have posted a new release (10-Aug-2018) in full installer and executable-only versions. Minor changes to help file.
Fixed crashing when closing transformations whose dialog boxes were open, when the close resulted from closing an image on which the transformation depended. This failed depending on whether the transformation dialog was opened for the first time or re-opened to edit an existing transformation.
Halftone: fixed problem causing custom image control not to be initially hidden if the screen was not set to Custom.
Posterize: fixed progress indicator and removed unnecessary recalculations in Refine Palette.
