Bug fix release 5-Aug-2018
I have posted a new release (5-Aug-2018) in full installer and executable-only versions. No changes to help file.
Added palette bar to the selective color correction control and transformation. This lets you create a new control point by clicking on a palette color, thus providing a mechanism to select colors from other images or from a pre-defined palette.
Adjust transformation: changed method of adding or removing color casts to match the way Color Balance works.
Fixed problem in Quick Pick not matching last character of command name.
Removed unnecessary recalculation of downstream images when closing a transformation that has just been inserted in a branch.
Fixed several transformations that were closing their dialog box after an Apply instead of keeping it open.
Made the thumbnails in the Rotate-Mirror transformation somewhat larger.
Fixed bugs in Mask when input image was zoomed or scrolled differently from the output image.
Added synchronized scrolling control to Advanced Sharpen, Bilateral Sharpen, Gaussian Blur, Unsharp Mask, Precise Gaussian Blur and fixed problem where display toolbar was getting out of sync with split screen when Mask was invoked.
