Alfabet list overides a "very" quick pick list
- type one or two letters to display a reduced list
- run the mouse over the listed transformation buttons -> they will change into alfabet list beginning with Add Border
for example, type cc and you get the following list:
Checker Board, Color Balance, Color Chart, Color Curves, Combine Channels
then run the mouse over the buttons and they will change to:
Add Border, Add Texture, Adjust, Advanced Sharpen, Line and Arrow
This does not happen if you first use the space bar and only then type some letters to reduce the list:
close the Quick Pick window, use the space bar to display full Quick Pick list, type cc, run the mouse over the buttons -> they will stay unchanged.
And this cosmetic observation:
If you happen to have at the same time open the Help window:
Click on it to make it current, then minimize it and go back to the Quick Pick window -> you will not find the cursor and you will not be able to get it back by clicking. However you will be able to type letters.
You will get the cursor back by making current any other running application and then returning back to PWP.
It looks like a kind of rivalry between the Dialog and a Popp Up modes.
