Bug fix release 2-Aug-2018
I have posted a new release (2-Aug-2018) in full installer and executable-only versions. Minor changes to help file.
Equalize transformation curve now works with a probe to display curve markers or insert new curve points.
Monochrome transformation: fixed problems causing coarse curve histogram display.
Fixed problem causing image browser not to refresh when clicking on a new image.
Fixed problem causing main image area to display incorrectly in split screen in some cases.
File Save: reduced the number of clicks necessary to select overwrite or rename when saving with the same name as an existing file.
