Adjust reset command does not control points
With color images the Reset command in the main tool bar does not reset the control points in Selective Color Corection tab
With black and white images it does not reset the points on the tint bar in Color tab.
Also, is it necessary to recompute all enabled trasformations in case you only switch the tabs without making any changes to settings and without enabling or disabling any of the operations? Curve, Color Balance and Selective Correstion are very fast but Bilateral Sharpen can take some time.
Re: Adjust reset command does not control points
