Bug fix release 26-Jul-2018
I have posted a new release (26-Jul-2018) in full installer and executable-only versions. Minor changes to help file.
Adjust – reduced the area you can click on to set the color balance color or selective color correction control points.
Changed layout of Selective Color Correction dialog box and made color wheel grow to fill available space as dialog is resized. Made color wheel background dark gray for Selective Color Correction and Adjust transformations to indicate the active area where you can click.
Copy transformation: fixed problem with input image menu.
Dragging the separator between the image browser and main image area now zooms to fit all images in the workspace.
Fixed bug in image browser causing connector lines between splitters and their branches to be drawn incorrectly if the image browser was scrolled to the right.
