A copy and paste tip
A double-click on a coppied and pasted image creates a duplicate of it. There is no mention about it in Help. Is it intended? It may come in handy if you know it. If you don't, you might experience some unexpected coppies of an image in the browser. I did. :)
Re: A copy and paste tip
To be consistent with File Open, it should probably give you the option of replacing the current image, or pasting a new top level image, or cloning the branch with a newly pasted image.
Talking about Copy transformation, when you reopen the Copy dialog and go to the Input image list, there is the Select solid color option which after selected, does not do anything and leaves the thumbnail empty. Only after you reopen the empty thumbnail, the Select solid color option is replaced by No image option.
