Bug fix release 26-Jun-2018
I have posted a new release (26-Jun-2018) in full installer and executable-only versions. No changes to help file.
Adding a new side branch to an image now sets the first empty branch to be current. Adding a new side branch to a splitter makes the new branch current.
Fixed bug causing certain transformations to fail to respond correctly to a double-click if one or more downstream images has a mask.
Fixed bug causing scripts saved without image names to give a File Does Not Exist warning.
Fixed bug in Bilateral Sharpening when reducing number of passes if current tab is one of the eliminated passes.
Re: Bug fix release 26-Jun-2018
Another improvement would be to keep an empty branch box current after the transformation has been cancelled or the dialog closed using X button.
Currently when you cancel a transformation on an empty branch box, the focus jumps to its parent input image and makes it current.
I think it should behave the same way as when you close the only output of a completed transformation -> the focus jumps to the empty branch box and makes it current.
