Executed Saved Script with lines in Amount Mask...
Ref: PWP 8.0.exe 180625 with msi 180621
1) Open the following saved script with an image of choice:
script 1.0
color_management enabled 0 on_mismatch 0 acs_profile ″″ gray_acs_profile ″″ wcs_profile ″″ gray_wcs_profile ″″ monitor_curves_file ″″ monitor_curves_enabled 0
image index 1 caption ″color_hexagon_HSV-V=100-1-1_Notated-1.tif″ parent -1 bypass -1 same_size 0 size_specific 0 n_inputs 0 n_masks 0 command ‴file_open pathname ″″ filetime ″″‴
end_image
image index 2 caption ″Color Curves″ parent 1 bypass 0 same_size 1 size_specific 0 n_inputs 0 n_masks 1 command ‴color_curves 0 curve1 2 2 0 128 255 128 curve2 5 2 0 0 18 26 89 166 204 222 255 255 curve3 2 2 0 0 255 255 colorspace 0 component 1 mask_histogram 0 amount 0 1 0 0 ″Amount: ″ ″Mask″ display 2 sync_scroll 1 auto_preview 1‴
mask base_image 2 mask_number 0 base_input_index -1 initial_image -1 initial_mask_index -1 initial_level 0 caption ″Mask″ command ‴mask 0 nx 660 ny 720 mask_color 0 mask_transparency 5 initial_level 0 n_op 2 command1 operation 7 mask_mode 0 mask_operation 7 colorspace 0 sample ff minb1 113 maxb1 993 minb2 0 maxb2 1024 minb3 0 maxb3 1024 minw1 143 maxw1 963 minw2 0 maxw2 1024 minw3 0 maxw3 1024 command2 operation 7 mask_mode 2 mask_operation 7 colorspace 0 sample ff minb1 0 maxb1 1024 minb2 0 maxb2 922 minb3 0 maxb3 1024 minw1 0 maxw1 1024 minw2 0 maxw2 845 minw3 0 maxw3 1024 ‴
end_image
end
Details/Annotations for this script are described here: http://www.l7.org/IMAGEs_by_DEN/tutoria ... stment.pdf
2) Initial executed script has Amount Mask lines resulting in unchanged saturation lines in the processed image...
Saved Script screen view 1.jpg (144.4 KiB) Viewed 2814 times
3) Selecting 'Edit Transform...', then 'Edit...' Amount Mask will clear the lines in the mask...
Saved Script screen view 2.jpg (131.28 KiB) Viewed 2814 times
4) A transform OK results in an expected processed image...
Saved Script screen view 3.jpg (146.47 KiB) Viewed 2814 times
Also, initial execution of the script will intermittently result in the Program disappearing from the desktop with no warnings or error messages.
P.S. All are welcome to download and use the script... ...a PWP7 discussion/examples may be found here: http://www.l7.org/IMAGEs_by_DEN/tutoria ... 180204.pdf
Re: Executed Saved Script with lines in Amount Mask...
I had a separate report of script problems which will be fixed in the upcoming 26-Jun release - when you get a chance, let me know if it fixes the problems with this script.
Ref: PWP 8.0.exe 180626 -- mask lines still present with crash for large images
Program consistently disappears from desktop with no warnings or errors when script is open with a 4896x3264 pixel, sRGB, jpeg image of 8.64 MB. Mask lines, if present should be readily apparant if the Open Image File dialog selected image for the script contains large areas of blue sky...
The illustrated image [PWP Color Hexagon] in the following screenshot is 660x720 pixels, sRGB, 24 bit tif, 1.6 MB...
Screenshot 180626.jpg (153.76 KiB) Viewed 2798 times
I found and fixed the problem with the horizontal bands, but I am not seeing the crash -- is there any way you can send me the jpeg image that causes it?
I was interrupted today and have done a system power-down and a system power-up. I am unable to duplicate the crash with the larger images but do still intermittently get the saturation line (bands) but not consistently.
Let's go with what you found for now... ...I will try to find out if something is peculiar with my OS and if I still experience problems with your future updates.
I did check this script with PWP 8.0.exe 180622 and several large/small images with no observed problems.
