Minimizing Mask Tool after minimizing Color Curves causes shutdown...
Ref: PWP 8.0.exe 180609 with msi 180606
1) open an image, sRGB 24 or 48 bit color
2) open Color Curves to HSV-S, load *.curve script:
Curve 1.0
npts 5
style spline
point 0 0 0
point 1 18 26
point 2 89 166
point 3 204 222
point 4 255 255
end
3) select New Amount Mask, load *.mask script:
mask 0 nx 660 ny 720 mask_color 0 mask_transparency 5 initial_level 0 n_op 2 command1 operation 7 mask_mode 0 mask_operation 7 colorspace 0 sample ff minb1 113 maxb1 993 minb2 0 maxb2 1024 minb3 0 maxb3 1024 minw1 143 maxw1 963 minw2 0 maxw2 1024 minw3 0 maxw3 1024 command2 operation 7 mask_mode 2 mask_operation 7 colorspace 0 sample ff minb1 0 maxb1 1024 minb2 0 maxb2 923 minb3 0 maxb3 1024 minw1 0 maxw1 1024 minw2 0 maxw2 845 minw3 0 maxw3 1024
4) minimize Color Curves transform dialog -- everything seems OK
5) minimize Mask Tool dialog -- system becomes busy, ie, mouse icon blinks and after a few seconds Program disappears from the desk top... ...no warnings or errors or messages.
This does not appear to be consistent with other transform - mask combinations but did not thoroughy investigate.
Occurs in this case even if the HSV-S curve and Mask Tool - Color Range settings are entered/applied manually.
Re: Minimizing Mask Tool after minimizing Color Curves causes shutdown...
Fixed for next release
